Re: varnish - how long
Posted by Steve Miller on Apr 26, 2005
Sam Devlin says a month. I have good luck with 2 weeks and use System 3 goo which can blush under the right conditions. The key thing is to wash, with water, before you ever start sanding. Water and a 3M scrubber pad. Rinse well, change water in your pail often and dry it off with paper towels. If in doubt wet sand after washing. The first coat may take a few days to cure but all the rest of the varnish coats will cure fine.
In Response to: Re: varnish - how long by CLC on Apr 26, 2005
