Re: Help Fairing Keel
Posted by Howard on Apr 23, 2005
matt,
if the hump is at the bulkhead, are you saying that when you cut the hull and put he spacers in that, that you cannot make what was the previous flat areas "peaked" enough to get a fair hull?
i guess what i am asking is that have you pushed the hull where you cut it far enough apart?
if the hump is caused by something else...can you try to describe it a bit more?
hs
In Response to: Help Fairing Keel by Matt Croce on Apr 22, 2005
- Re: Help Fairing Keel by Matt Croce on Apr 23, 2005
Nevermind... by Matt Croce on Apr 23, 2005
- Re: Nevermind... by Dick R on Apr 24, 2005
