Re: Apartment Pram
Posted by Howard on Apr 23, 2005
double check the measurements...but is suspect if you turned it up on its side (holding the front and back, rotate it 90 degrees -- as if it was a mattress) and carried it out the door you would have no problem.
i do not think there is any height measurement approaching close to 30".
need to make, however, that outside the 30" door you have space and you are not turning into a narrow hallway.
hs
In Response to: Apartment Pram by Paul on Apr 22, 2005
