Re: bulkead issues
Posted by Laszlo on Apr 23, 2005
Yes.
With any luck at all you won't have an actual gap (or at least a very small one), but it'd be a very good thing to reach into the cockpit and put faired bead of putty on the deck/bulkhead joint. It'll seal any leaks and help distribute the deck loads. If you're putting in hatches, do thesame to the other sides once you have access.
Good luck,
In Response to: Re: bulkead issues by Rocko McCombs on Apr 22, 2005
