Re: sealing rigging screw
Posted by Chris Taylor on Apr 22, 2005
I avoid the silicon and use only epoxy to seal the screw holes. The problem with silicon is that it can get on the varnish and may be very difficult to get off when you go to refinish the boat in future. Sanding can spread the little bits of silicon contamination around making the new coat of varnish bead up.
In Response to: Re: sealing rigging screw by Howard on Apr 21, 2005
- Re: sealing rigging screw by LeeG on Apr 22, 2005
- Re: sealing rigging screw by Steve on Apr 22, 2005
