Re: Keel Line
Posted by david delucia on Apr 21, 2005
one other thing you may want to try is place the hull on flat 2x4 or 2x6 and put tack pins the type used for bulliton boards along the keel on the inside starting from the center and working your way out.your not going to go all the way to the both ends of the boat.youl keep back a few ft from both ends.an other thing just do the keel only dont glue the the other seems at this time. if you go for this make sure you have wax paper between the 2x and the hull so as not to glue boat to 2x.
In Response to: Re: Keel Line by CLC on Apr 21, 2005
