Re: MC16.5 Trolling motor
Posted by CLC on Apr 20, 2005
I have photos somewhere of two installations: One had a tricky rudder-like mount on the stern, operated by footpedals. A customized mount had to be fabricated, which not only turned for steering but also kicked up if you hit something. The kit builder worked in a machine shop, if memory serves.
There was another one that used a side-slung motor mount on the aft deck. Really the simplest solution; just a plank with a curved adaptor for the aft deck radius, and a block of wood to clamp the motor to.
Clearly a rig suitable only for calm water, but both iterations were said to run well.
In Response to: MC16.5 Trolling motor by Pat Ferguson on Apr 20, 2005
- Re: MC16.5 Trolling motor by Gafrick on Apr 21, 2005
Re: MC16.5 Trolling motor by terry on Apr 21, 2005
- Re: MC16.5 Trolling motor by Brett on Apr 21, 2005
- Re: MC16.5 Trolling motor by Ed, NY on Apr 21, 2005
- Re: MC16.5 Trolling motor by terry on Apr 22, 2005
- Re: MC16.5 Trolling motor by CLC on Apr 22, 2005
