Re: Footbrace mounting st
Posted by Howard on Apr 17, 2005
i have seen somebody use an approach of cutting U shaped pieces of wood where the open part of the U is the shape of the end of the track. the U shape is as thick as the track...then glued into the hull. the track is then fitted into the U's and a small plate is put accross the top of the U to hold the track in.
hs
In Response to: Footbrace mounting studs by Brett on Apr 17, 2005
