Re: preparing for varnish
Posted by ray on Apr 17, 2005
cheers steve
that is really useful.
i will add another coat of epoxy.
would you wet and dry between epoxy coats or use dry sand paper.
Any idea how much varnish is needed to do four coats on a ch17? Is 3/4 litre enough (varnish & hardener) Is it ok to add thinner to make it go further. if so how much?
you probably guessed, i've never used varnish for anything. any help is appreciated.
ta
ray
In Response to: Re: preparing for varnish by Steve Miller on Apr 17, 2005
- Re: preparing for varnish by Doug on Apr 17, 2005
- Re: preparing for varnish by Steve Miller on Apr 17, 2005
another question by ray on Apr 17, 2005
- Re: varnish relects base by Scot on Apr 17, 2005
- Re: another question by Steve Miller on Apr 17, 2005
- Re: another question by ray on Apr 18, 2005
