Re: decorative inlays
Posted by Dennis Rioux on Apr 15, 2005
Kevin,
You should be able to find veneers at woodworking stores (like Woodcraft) or even hobby stores.
If you want to do an onlay it may be difficult to hide the edges with just varnish coats. I built little tape dams to make epoxy transition ramps between the onlay and the deck and then buried it all underneath the deck glass. I did some badges of beech & sapele at the butt joints at the cockpit (they hide a multitude of sins) and one at the deck tip scarf joint like in the photo (the name is on rice paper which I sent through a laser printer -- the paper becomes mostly transparent when wetted out with epoxy). There are a few more photos of the actual process that might be helpful on my web site. There are probably quite a few more options and details to be found in the archives too. Good luck.
Dennis
Building the CLC WR18
In Response to: decorative inlays by Kevin on Apr 14, 2005
- Re: decorative inlays by Karl on Apr 15, 2005
Re: decorative inlays by Dennis Rioux on Apr 15, 2005
- Re: decorative inlays by Kevin on Apr 16, 2005
- Re: decorative inlays by Dennis Rioux on Apr 18, 2005
