Re: Inside Finish
Posted by LeeL on Apr 15, 2005
Hi Rocko:
You have several options, you could paint the entire cockpit area. Or go ahead with a coat of varnish.
I don't think that you need to sand or varnish those areas in the cockpit that are not exposed to sunlight, such as the underside of the deck and the forward area of the cockpit. The only reason varnish is needed is for protection of the epoxy.
In Response to: Inside Finish by Rocko McCombs on Apr 15, 2005
