Re: Epoxy time
Posted by CLC on Apr 13, 2005
I second all of Lee's remarks. If it's really 65 degrees and three weeks later the cure is incomplete, then something was awry in the mix.
Heat, heat, heat. Cook it and it may fire off.
A second, properly catalyzed coat on top of the first WILL help the bad mix underneath.
In Response to: Epoxy time by Michael on Apr 11, 2005
