Re: rudder
Posted by terry on Apr 12, 2005
Moe,
As LeeG just said, a rudder can easily be mounted later.
Do you need one? If you are a skilled paddler, no you don't need one. I have boats with and without rudders. In high winds, the rudder is very helpful and I really like to have it. In light winds, it's not necessary and I usually retract it.
A Chesapeake 18 is a large kayak and it presents a lot of surface area to the wind, so the rudder might be more useful on this larger kayak.
So try out your wonderful new boat on some windy days in the fjord, paddling into, away from and across the wind, and see if you can comfortably control the boat. If not, add the rudder.
And good luck paddling over there in beautiful Norway!
terry
In Response to: rudder by Moe on Apr 12, 2005
- Re: rudder by Paul on Apr 12, 2005
Re: rudder by Mark Camp on Apr 12, 2005
- Re: rudder by LeeG on Apr 12, 2005
- Re: rudder by terry on Apr 13, 2005
- Re: rudder by LeeG on Apr 13, 2005
- Re: rudder by Steve on Apr 22, 2005
