Re: Heat Guns on Minicell
Posted by terry on Apr 12, 2005
Hi Mac,
You may want to check out the Material Safety Data Sheet (MSDS)for the minicell. CLC could probably give you the manufacturer's name and they will give you the MSDS. That way you can see what happens to the foam when heated to the melting point.
One of the other builders may already have this information.
In Response to: Heat Guns on Minicell by Mac on Apr 12, 2005
