Re: Brightside sun exposu
Posted by Howard on Apr 8, 2005
the finish will last longer if you can keep it out of direct sunlight. but if you put a tarp over it it can hold moisture against the hull which is also pretty tough on the paint/finish.
i would rather have it dry and in the sun then having a tarp hold moisture up against the hull.
hs
In Response to: Brightside sun exposure by Aaron J. on Apr 8, 2005
- Re: Brightside sun exposu by Mac on Apr 9, 2005
