Re: Scarfs for Bright fin
Posted by terry on Apr 8, 2005
Yes
You can color it with a mixture of cabo-sil and wood flour, but it will still show.
If the directions don't advise this, it's a good idea to put packing tape on either side of this joint to prevent the glue from oozing farther than it should.
Good luck with that bright finish. Many of us avoid them because of the extra care in construction required to get a pretty hull. But it is worth the effort.
terry
In Response to: Scarfs for Bright finish by Paul on Apr 8, 2005
- Re: Scarfs for Bright fin by Doug on Apr 8, 2005
Re: Scarfs for Bright fin by Paul on Apr 8, 2005
- Re: Scarfs for Bright fin by Steve Miller on Apr 8, 2005
