Glass Tip
Posted by Rand on Apr 6, 2005
Had another boat builder friend arrive at the workshop yesterday as I was doing some glassing. I was just dealing with all the corners where deck meets hull with my usual trick of cutting 50mm circles of glass and forming them around the corners. He said he hadn't seen that before so I thought I would mention it on the forum. Basically the little pieces form quite nicely around most corners as you can "push the grain" of the glass in most directions. Saves having all those sticking-up bits that usually happens at corners.
- Re: Glass Tip by Mac on Apr 6, 2005
Re: Glass Tip by Rand on Apr 7, 2005
- Re: Glass Tip by terry on Apr 7, 2005
- Re: Glass Tip by Mark on Apr 7, 2005
- Re: Glass Tip by Mac on Apr 7, 2005
