Re: Major Screw Up?
Posted by Howard on Apr 1, 2005
i think duane is right on...but you may have difficulty with a razor.
a sabre/jig saw can also help you reopen a seam that has been glued..just use a fine tooth blade and go slow to stay right on the line. you will need to drill a couple 1/8 or smaller holes to give you a starting place to get the blade in there...but once you do that...its pretty easy with a power tool.
hs
In Response to: Re: Major Screw Up? by Duane Strosaker on Apr 1, 2005
