Re: Major Screw Up?
Posted by Duane Strosaker on Apr 1, 2005
It is easy to fix. Now or after your trip, use a razor to cut through the epoxy in the seam of the hollow area. Use a few small wedges of wood to spread the seam area of the hollow so that it smooths out. Then fill in the gap in the seam with some thickened epoxy. The fiberglass you add later on the outside and inside will reinforce it.
Duane Strosaker Southern California
Roll or Drown
In Response to: Major Screw Up? by Matt Croce on Mar 31, 2005
