Re: glassing under the de
Posted by LeeG on Mar 31, 2005
sure. I've done it on four s&g kayaks. A Northbay aft deck. The first Pax20 prototype foredeck without kingplank. A 18'x21.5" s&g fore&aft deck with a thin 3/16" thick stringer up the center of the foredeck and no front bulkhead. A Ch18 fore and aft deck. If you put the 4oz glass on diagonally, then put the fill coats on while the wet-out coat is barely tack free it'll all go on just fine.
In Response to: glassing under the deck by John P on Mar 31, 2005
