Re: glassing under the de
Posted by Howard on Mar 31, 2005
the arctic hawk calls for 2oz cloth pre-glassed on the inside of the deck...both front and aft.
on the aft deck, immediately behind the coaming through about another 24 inches aft...they call for two additional layers of 2oz (total of 6 oz) prior to installing the decks.
the only issue i found is that where the deck is highly can see a bit of white streak where the glass was pulled, i suppose out of its matrix. so if i had to do it again..i would recommend that the installation of the deck take place while the epoxy is green or not fully cured.
In Response to: glassing under the deck by John P on Mar 31, 2005
