Re: fore bulkhead too low
Posted by Rob, Australia on Mar 27, 2005
After carefully tracing the fore bulkhead profile for the Ch16.,I found it was too small. This was picked up by running a string line from the deck beam to the bow and measuring the distance from the string to the top of the 'wrong' bulkhead. It was a simple procedure to make another of the correct dimension. As everything else has worked out, even the conversion from imperial to metric, I have to believe it was me and not the drawings. Has anyone else had this problem?
In Response to: fore bulkhead too low by Vic F on Mar 22, 2005
