CLC Internal Footbrace
Posted by Vike on Mar 24, 2005
Has any one who has used this system had any problems once installend. Are they durable and can they take the pressure from ones feet and pushing on them? I did just bought a set to install on the Artic Hawk that I'm building. I did not want to install through the hull bolts. I also thought about Kurts wooden block mehtod, but feel CLC studs are probably simpler to use ( no having to make blocks and aluminum cover plates ).
Any how unless there is any good tips that come in on this I will install as the CLC enclosed instructions state.
Thanks Greg
