Re: fore bulkhead too low
Posted by george on Mar 22, 2005
'It depends. How much gap ya gonna have? If it's a small amount, I think you could plane the sheer down to meet the radius, recognizing you will also lose some 'height' in the cockpit. Alternative is to plane the sheers, apply the deck, then fill the space with dookie . I did that, used a plastic-covered 'dam' on each side to keep the thickened epoxy home, and the result was very acceptable; gives the surface of the dookie a shiny, 'finished' look, too. Either way works.
In Response to: fore bulkhead too low by Vic F on Mar 22, 2005
- Re: fore bulkhead too low by Vic F on Mar 23, 2005
Re: fore bulkhead too low by Howard on Mar 23, 2005
- Re: fore bulkhead too low by george on Mar 23, 2005
- Re: fore bulkhead too low by Paul on Mar 25, 2005
