Re: Lateen Sails
Posted by Charlie on Mar 20, 2005
The amount of sail you can fly depends a lot on your abilities and how crazy you want to get. A 30lb Sea Snark carries 45 sq. ft. of sail but you might not want to be in it if the wind gets above 15 mph. You can probably put up 5 sq.ft. more than you're using know if your mast can handle it. Charlie
In Response to: Lateen Sails by Ken Golden on Mar 19, 2005
