Re: sand paper grit
Posted by Cliff Herring on Mar 17, 2005
Don't know if anyone has mentioned this to you, but definitely get a carbide tipped scraper. They save much sanding and you can remove only what you need to (runs) without hitting the surrounding area. First scrape, then sand (epoxy).
In Response to: sand paper grit by Patrick Forrester on Mar 17, 2005
