sand paper grit
Posted by Patrick Forrester on Mar 17, 2005
I purchased a random orbital sander, and bought some 8 hole paper to go with it.
I bought 15 - 120 grit sheets and 15 - 220 grit sheets This is all my local store had. Anyway I am ok with buying other grits if necessary.
I am wondering what I should use to clean things up before glassing the hull and deck. And what I should use to sand down everything after glassing and expoxying is done. And what I should use between coats of varnish.
I did a quick clean up with 220 on the hull, and it took everything down real fast. I am anal enough to go higher, but I am afraid it may be too smooth for max adheasion of the glass.
I am looking forward to seeing your ideas. Thanks
- Re: sand paper grit by Mac on Mar 17, 2005
- Re: sand paper grit by Mark Camp on Mar 17, 2005
- Re: sand paper grit by Cliff Herring on Mar 17, 2005
Re: sand paper grit by Gert Walter on Mar 18, 2005
- Re: sand paper grit by Mac on Mar 18, 2005
- Re: sand paper grit by terry on Mar 18, 2005
- Re: sand paper grit by Karl on Mar 18, 2005
- I'm with Mac by Gafrick on Mar 20, 2005
- Re: Dust Bag by Mac on Mar 20, 2005
- Re: sand paper grit by Mark Camp on Mar 18, 2005
- sigh- If you are glassing by Charlie Jones on Mar 20, 2005
Re: sigh- If you are glas by Mac on Mar 20, 2005
- exactly why I do it by Charlie Jones on Mar 20, 2005
- Re: sigh- If you are glas by Rand on Mar 20, 2005
