Cool Tools you will need.
Posted by Howard on Mar 16, 2005
Now you got it. Kayak building not only appeals to your instinct to create....but is wonderful for the instinct to collect cool tools as well....
While i would not at all consider this an exhaustive list....here are some "optional" other cool tools that that i convinced my spouse are important in getting a good build and are easily amortized over the many boats that you will eventually build. i am sure others can chime in...
- drill press - bench sander/shaper - complete dremel kit - jig saw/sabre saw - battery powered drill - drum sanding kit - countersink kit - complete drill kit between 1/32 and 1/2 inch in 1/64th increments. - finger plane - small power sanders that can get into small places like the fein sander
good luck
In Response to: Re: Sheer Clamp Joint Wea by Matt Croce on Mar 16, 2005
