Re: Sheer Clamp Joint Wea
Posted by Matt Croce on Mar 16, 2005
Thanks again everyone for your help. After letting the joint dry, and sanding it clean (even filled in some small surface voids with epoxy/wood flour mix, I'm picky that way), it looks great, and easily passes the "pick it up by the end" test that you suggested.
I'm going to round off the sheer clamps before moutning as you all suggested as well; I "need" to go buy a router to do it. (Great idea building a boat; it gives me ammo to explain to the wife why I NEED a new tool!)
Thanks again, Matt
In Response to: Sheer Clamp Joint Weak? by Matt Croce on Mar 15, 2005
- Cool Tools you will need. by Howard on Mar 16, 2005
