Re: Sheer Clamp Joint Wea
Posted by CLC on Mar 16, 2005
I looked at the photo and it looks fine. I second Howard's remark that if you can pick up the sheerclamp without ominous cracking noises being heard, there's no reason for concern. Also ditto on it being even stronger once you glue it onto the side panel.
In Response to: Re: Sheer Clamp Joint Wea by Cliff Herring on Mar 16, 2005
- Re: Sheer Clamp Joint Wea by Josh G on Mar 16, 2005
