Re: Footbrace mounting
Posted by George on Mar 15, 2005
Sorry 'bout that empty post; ... I used the CLC system; worked great (same boat). You will sandwich the base in epoxy saturated fiberglass, which will of course pass through those mounting holes. That base and stud isn't going anywhere....
Very substantial mount for your footbraces. I don't know what the 'failure weight' would be to tear one of those studs loose, but you won't do it by paddling.
In Response to: Footbrace mounting by Mark on Mar 14, 2005
- Re: Footbrace mounting by Mark on Mar 15, 2005
