yes, it is
Posted by Charlie Jones on Mar 13, 2005
as you have found out, the cheapies aren't really cheap- they don't hold up. Get the yellow ones, cut them in half and use that. In fact I cut them into two 3 inch chunks and using the one inch left over to dut into chunks that I stick into a handle and use that for foam glue brushes. If you can find the 9 inch rollers so much the better- they make three 3 inch rolers from each one.
In Response to: Re: final epoxy coats by Vic F on Mar 13, 2005
