filling seams w peanut bu
Posted by Patrick Forrester on Mar 12, 2005
The West River 18 manual says. Fill the seams on the exterior of the hull with "epoxy peanut butter" to join the hull. In many places it appears as though the joints are too small to effectivly fill with peanut butter. I guess that I will make a mess out of it if I try to push the peanut butter into all joints. Am I correct when I assume this ? Is it ok if I do not bond the very tight seams ? Or should I use unthickend epoxy in a syringe for the tight joints ? Or is there another idea I have not thougth of ? thanks
