Re: Second try on image
Posted by Ken Leffert on Mar 11, 2005
A pullsaw is just the trick here. I used a Marples from Home Depot, line it up with the end of the bottom panels, cut through both side panels, re-wire the sides. I'd almost bet that CLC plans on the sides being longer, as yours are, because thats a much easier fix than if the bottoms are longer.
In Response to: Second try on image by Dames on Mar 11, 2005
- Re: Second try on image by Doug Judd on Mar 11, 2005
No big deal by Howard on Mar 11, 2005
- On further investigation. by Ken Leffert on Mar 11, 2005
