Re: Finishing questions
Posted by Steve Miller on Mar 8, 2005
Once you are smooth then you only need 400 grit (wet) between coats. I only sand every other coat so I build thickness faster. In between coats if I am not sanding I use a 3M pad (fake steel wool). Scrub with it lightly until the gloss is gone and the dust bunnies are smooth. My last coat is always one after sanding however.
In Response to: Re: Finishing questions by Karl on Mar 7, 2005
