Re: Planing sheer clamps
Posted by Brad on Mar 3, 2005
I understand the 24 to 30 inch radius transition. My concern is that when the sheer is planed to a 30" radius the angle from horizontal is 27 degrees. When you lay a protractor across the sheer and carlin the angle is 13 degrees. the side deck plywood would make a 14 degree bend in 3 1/2 inches. Will the plywood bend that much without a gap around the outside edge?
Here are links to photo's of what I'm talking about. They're taken at the rear hanging knee.
http://www.forumpictureprocessor.com/pictureprocessor/images/100_0321_1.jpg
http://www.forumpictureprocessor.com/pictureprocessor/images/100_0320_1.jpg
In Response to: Re: Planing sheer clamps by CLC on Mar 3, 2005
