3mm hull
Posted by CLC on Mar 1, 2005
I second Lee's remarks, especially about the width of the panels. A 3mm boat with wide spans across the panels is going to be flexible and even fragile unless it has a lot of fiberglass, which of course would defeat the purpose of going with lighter plywood.
In Response to: depends by LeeG on Mar 1, 2005
- Re: 3mm hull by LeeG on Mar 1, 2005
