Re: 3 MM hull?
Posted by Kyle T on Mar 1, 2005
All good questions. 3mm is 8 LBS a sheet vs. 12 LBS for 4mm. My sheet layout will use most of 3 sheets per boat. Probably a savings of close to 10 LBS overall. I've built enough to know how to avoid adding unnecessary weight while glassing so I am looking elsewhere for additional savings.
I am planning to use shear clamps for the hull to deck join and I think they will go a long way to ensure that I get fair curves during the build.
I'm really not too concerned with strength of the 3mm for the intended use of these boats but I am concerned with flex in the hulls. I was planning to use 6 oz glass in the complete interior of the hulls to help stiffen them up but now that you mention it I may opt for carbon fiber under each cockpit. I used CF for my stripper tandem and it really made for a very rigid floor bottom.
Thanks, --KT--
In Response to: Re: 3 MM hull? by Howard on Feb 28, 2005
- Re: 3 MM hull? by BobE on Mar 1, 2005
- Re: 3 MM hull? by terry on Mar 1, 2005
- your target weight? by Howard on Mar 1, 2005
Re: your target weight? by Mark Camp on Mar 2, 2005
- elaboration by Howard on Mar 2, 2005
- Re: elaboration by LeeG on Mar 3, 2005
- Re: elaboration by Mark Camp on Mar 4, 2005
Re: your target weight? by Kyle T on Mar 2, 2005
- Re: your target weight? by Howard on Mar 2, 2005
- Re: your target weight? by LeeG on Mar 3, 2005
