3 MM hull?
Posted by Kyle T on Feb 28, 2005
Has anyone here ever built a boat with the lighter 3MM plywood that CLC sells? If so were you happy with the results?
I'm just about to start building two S&G tandems of my own design that will be used during a three-day adventure race across the Everglades later this year. There will be a lot of portage involved so we want the boats as light as possible. Since there will be no rough surf nor rock gardens I am thinking about going with the 3MM even though it has to be more damage prone.
Any comments?
Thanks, Kyle T.
- Re: 3 MM hull? by Howard on Feb 28, 2005
Re: 3 MM hull? by Kyle T on Mar 1, 2005
- Re: 3 MM hull? by BobE on Mar 1, 2005
- Re: 3 MM hull? by terry on Mar 1, 2005
- your target weight? by Howard on Mar 1, 2005
- Re: your target weight? by Mark Camp on Mar 2, 2005
- elaboration by Howard on Mar 2, 2005
- Re: elaboration by LeeG on Mar 3, 2005
- Re: elaboration by Mark Camp on Mar 4, 2005
- Re: your target weight? by Kyle T on Mar 2, 2005
- Re: your target weight? by Howard on Mar 2, 2005
- Re: your target weight? by LeeG on Mar 3, 2005
- Re: 3 MM hull? by Mac on Mar 1, 2005
- depends by LeeG on Mar 1, 2005
3mm hull by CLC on Mar 1, 2005
- Re: 3mm hull by LeeG on Mar 1, 2005
- Re: 3 MM hull? by Kyle T on Mar 2, 2005
- Re: damage during portage by LeeG on Mar 2, 2005
