Re: fairing the keel line
Posted by CLC on Feb 26, 2005
With the epoxy already cured, you have two choices: First, apply "bondo" (actually, microballoons set in epoxy is the preferred "bondo" mix). Or, second, if the deck isn't on yet, you can actually slit the keel seam in the affected area with a saber saw, adjust the panels, and re-apply an epoxy fillet from the inside.
I've done both and the second is the preferred approach because it'll be invisible even if the whole hull is varnished.
In Response to: fairing the keel line by Tony on Feb 26, 2005
- Re: fairing the keel line by Charlie on Feb 28, 2005
