Re: Sanding tips
Posted by Steve Miller on Feb 24, 2005
As much as you can recoat within the no sand window. Add your next coat as soon as you can without messing up the old one. In the summer I have gotten 3 coats on in one day. I can normally do 2 a day in the winter if the shop is heated. Once the goo goes too far into curing you must sand. That time varies by manufacturer. Check with them. 24 hours is probably pretty safe.
In Response to: Re: Sanding tips by Parke on Feb 24, 2005
