Re: Scraper in Houston
Posted by Karl on Feb 14, 2005
Yep, After reading most of this thread I went to my local True value and picked me a carbide scraper for the princely sum of 13.99 + Taxachusetts' cut. Now if I only Knew how to use it... BTW, I 'glassed the deck this weekend. I used Mr. Noeske's trick of using the masking tape/plastic and then cutting the sharp line just above it with a razor knife. Worked like a charm. Went over it afterwards with a fill coat, rolled and tipped right down over the edge and onto the hull sides, and the line just about disappeared. I appreciate the tip.
ps. The sunset pattern I put the bow came out terrific. Once encased in 'glass you can see the different grain patterns standing out. I'll get pictures as soon as possible.
In Response to: Re: Scraper in Houston by terry on Feb 14, 2005
