Re: don't forget the fore
Posted by CLC on Feb 5, 2005
I'll second the foredeck issue---probably impossible---and add that I worry about the bottom panels forming up right in 6mm. Part of what makes the Chesapeake 16 pretty is the near-90-degree twist of the bottom panels up into that fine underbody at the bow.
6mm marine plywood isn't just 33% thicker than 4mm; it's got another two veneers and all the associated glue in it to make it even stiffer.
In Response to: don't forget the foredeck by Howard on Feb 5, 2005
- Re: don't forget the fore by allanreade@paradise .net. on Feb 5, 2005
- Re: don't forget the fore by Vic F on Feb 10, 2005
- Re: don't forget the fore by Stephan Bradley on Feb 5, 2005
try the skiff by Howard on Feb 5, 2005
- Re: try the skiff by Stephan Bradley on Feb 5, 2005
