Re: deck glass etc.
Posted by Steve Miller on Jan 31, 2005
Sanding the wood prior to glassing risks going right through the top veneer layer. BAD idea if you are going for a bright deck. I would do no more than knock it down with a 3M pad to knock off the wood grain fuzz or even just give it a good wipe down with a clean rag.
Sanding after glass and all your fill coats is where they want it done to minimum 220 since varnish has a hard time filling in coarser sanding scratches.
In Response to: Re: deck glass etc. by terry on Jan 31, 2005
