Re: Foam in flotation tan
Posted by Laszlo on Jan 26, 2005
Lee makes an excellent point. I've used foam in other boats and the best time to put it in is before the tank is sealed. If you have sealed it, you need to make sure that the tank has enough openings to allow the foam to expand without putting undue pressure on the wood, even if means cutting temporary openings and patching them after the foaming is done. A 2-part closed cell structural foam (the only kind you should use on a boat) WILL split the tank wide open if improperly applied.
In Response to: Re: Foam in flotation tan by LeeG on Jan 26, 2005
- Re: Foam in flotation tan by bert eugenio on Jan 26, 2005
- Re: Foam in flotation tan by RogerJ on Jan 26, 2005
- Re: Foam in flotation tan by Greg Swarthout on Jan 26, 2005
- Re: Foam in flotation tan by Greg in Vancouver on Jan 27, 2005
- Re: Foam in flotation tan by terry on Jan 27, 2005
- Re: Foam in flotation tan by Mac on Jan 27, 2005
- Re: Foam in flotation tan by Charlie on Jan 27, 2005
- Re: Foam in flotation tan by Laszlo on Jan 27, 2005
- Re: Foam in flotation tan by RogerJ on Jan 27, 2005
- Re: Foam in flotation tan by Greg in Vancouver on Feb 26, 2005
