Re: sanding coats of epox
Posted by Doug Judd on Jan 19, 2005
David, I used the tip of a sharp razor knife to pick out bristles before the epoxy was cured. If you eye-ball along the recently coated finish, bristles stick out like a sore thumb.
For those you miss that get fully cured into the epoxy, follow Tony and Mac's advice.
Less epoxy...less weight you have to manhandle to a roof rack.
In Response to: Re: sanding coats of epox by Mac on Jan 19, 2005
- Re: sanding coats of epox by Kurt Maurer on Jan 20, 2005
