Re: sanding coats of epox
Posted by Tony Calvert on Jan 19, 2005
I'd use a scraper to get the drips and brush bristles out and put another coat of epoxy on, assuming you are still within the chemical bonding window.
If you are outside the window use the scraper then a quick rub all over with a coarse scotch bright should do the trick of creating a good mechanical bond.
In Response to: sanding coats of epoxy by David G on Jan 19, 2005
- Re: sanding coats of epox by Mac on Jan 19, 2005
Re: sanding coats of epox by Doug Judd on Jan 19, 2005
- Re: sanding coats of epox by Kurt Maurer on Jan 20, 2005
