sanding coats of epoxy
Posted by David G on Jan 19, 2005
After starting my first boat, I've checked in this forum daily and utilized all your tips and techniques and so far, all is great! My question now is that I've applied one coat of epoxy to deck and hull; after drying, I've noticed sags and brush bristles (tipping to eliminate bubbles) - should I sand now to get them out or put two more coats of epoxy over them to hopefully level them all out and save the sanding until the very end? Thanks a bunch.
David
- Re: sanding coats of epox by Tony Calvert on Jan 19, 2005
Re: sanding coats of epox by Mac on Jan 19, 2005
- Re: sanding coats of epox by Doug Judd on Jan 19, 2005
- Re: sanding coats of epox by Kurt Maurer on Jan 20, 2005
