Re: beginner
Posted by CLC on Jan 18, 2005
>>>>>I am just curious if i can paint the wood before i finish it? if i do not want that wood grained look.
You may certainly paint the boat if you like; many do. Specifically to your question, the paint is the last thing that goes on. Because the epoxy and fiberglass sheathing on the boat is clear, the wood-grained look persists almost to the end of the project, at which you either varnish to preserve and enhance the look or paint the hull for a sleeker, post-modern appearance.
A painted hull
In Response to: beginner by Clayton on Jan 18, 2005
