Re: MC13 Wood
Posted by CLC on Jan 11, 2005
6566 plywood is a toss-up. Sometimes it's as bad as lauan. Sometimes it's pretty nice, but you might not know until you run into a delamination or a void. As a percentage of the total cost of the project in time and money, and weighed against the long life of these boats, the plywood is a small chunk. Get nice plywood.
If you're very careful and you use the full-sized layout in the MC13 plans, you can fit all the side panels onto one sheet. An extra sheet of 4mm WILL make it easier, but there'll be some waste.
In Response to: MC13 Wood by Gafrick on Jan 10, 2005
